Hello all,
I've had sporadic misfires for the last year or so, which are getting worse. It started after I changed the spark plugs. I installed AC Delco Copper 41-601 plugs. After this, I noticed the slight misfires, and a rougher idle. The misfire only happens under about 2/3rds throttle and doesn't really sputter until the engine is at around 3k RPMs.
To troubleshoot, I move the spark plug to #6, the spark plug wire to #5, and swapped the coil pack for 3/6 with 4/1. The misfire is still there, and it still exhibits the same behavior, but now it is on #6. I then moved the spark plug (originally from #3, now in #6) into #4. The misfire stayed on #6.
I'm thinking that this leaves me with a bad ignition module. It has the same slot/spot for both #3 and #6.
Does this make sense? Is it possible that this is a wiring problem to the ignition module?
thanks !!!!!
You guys rock, BTW
-Jason
thanks !!!!!
You guys rock, BTW
-Jason
