stevek
If my battery remains hooked up then I have a parasitic electrical drain. I have removed ALL of the fuses and it still happens. It is a brand new Everstart battery and it happened to the one I had to replace because of this issue. If the battery gets below 12.7 volts(checked with my meter) then I get a loud "clang" on the flexplate from low voltage.I just replaced the starter because it sheared of the teeth when I turned it over while it "clanged". I shimmed the starter. When I had this motor in my 82 Z-28 I had no issues. Even though the computer has been eliminated I still have a lot of electrical issues. I have hooked up the positive meter lead in circuit with the ground off but hooked to negative meter terminal and do not see any drop in amps or volts. Any thoughts? Thanks
