Starting prbolem
cjapa
I have a 2000 sunfire the car start after siting all night but when i drive it around and the engine gets hot, i turn it off most the time it wont start back up when i go to leave. I checked the battery wires there clean and i dont think its the starter i got a brand new one 2 years ago any ideas on what it may be?
ps. seems to do it alot more when its hot out
did you check if the connections to the battery and the starter and the ground are tight?
Did you have the battery tested?
yea everything seems tight, battery should be good to wen i go to start it the lights don't deem and everything works inside lights radio and so forth
could be the starter solenoid or a relay
