My 2005 Montana wont start when you turn the key on everything flashes and it clicks and then when you try to start it it just sounds like a clicking noise coming from the glove box area any suggestions
12.0 no loose connection. Changed relays around n it started then when turned n tried starting again it wouldn't start. I've looked at wires under driver side dash wow a mess a lot of wires has black tape. I can't afford to another day of work.
after having the battery charged, using the voltmeter check the main battery post on the starter to see what reading you get there when trying to start it. If you get at least 12 volts and nothing happens I would suspect the starter. You can pull it and have it tested at a parts store.
