96grandam2.4
- Apr 4, 2013
Hey guys need some help here.
1996 GRAND AM SE 2.4 AUTO.
The other day i had to install a new bulb in the inst cluster.
I didn't unplug the cluster itself only the acc items that prevent me from removing the dash/ bezel cover to access the cluster.
So anyways i install bulb it wasn't locked in properly, so i had to turn key on to move shifter out of the way to remove the dash cover, had to do this twice actually, bulb wasn't cooperating.
So i turn on lights to verify if the bulb works before i reinstall everything, and for some stupid reason i tried starting the car to power everything up, and all it did was start and die 2 sec later, i was like OK no biggie.
So i install everything and go to start it again, and it starts and dies 2 sec later, and that's whats its been doing for the last several days.
I tried to start it again tonight when i got home, and the battery would not even click, i checked the voltage it was at 10.5, the dome light and other lights real dim.
So my question, could a bad battery keep my motor from running once started or am i looking at something else here?
When i have the key on, all the instrument lights are on, none are flashing, and i don't have a scanner to check for codes, so what could be the problem?
I ask about the battery because i owned a 98 blazer and when the battery was on its way out, it made things go haywire with the electrical system with it.
