R
Redlined WS 6
I replaced my clutch master cylinder and my clutch still is messed up. It only happens when I run it hard though it is fine when im just driving around. On the track last weekend I tried to go from 3rd to 4th and the clutch was stuck basically. could this be a shimming problem?? i was thinking it could be that because this only happens when it gets hot which would cause some expansion and if its shimmed to tight the clutch may not be able to release far enough for the synchronizers to stop it. any opinions? thanks
