Still no spark on my '71 Lemans Sport 350
Richw7
Still no spark on my '71 Lemans Sport 350! I changed the plugs, wires, points, condenser & coil. I am getting 12 volts at the positive terminal of the coil with the key on. I followed the manual down the check list - 1) Disconnect wire at plug, check for spark 1/4" from engine - no spark. 2) Remove coil wire from distributor, check for spark 1/4" from engine - no spark. 3) connect test light from neg side of distributor to ground, turn on ignition - test light lights. 4) connect test light from point set lead connection to ground-open points (this I'm a little confused on, does this mean from the wire on the points to the base of the points set? 5) Test the coil & condenser - they are new. Any suggestions other than buy another coil & condenser? Thanks!
what voltage reading do you get at the positive side of the coil while cranking the engine to start? did you set the point gap? If you set the point gap, how did you do it?
No spark on my '71 Lemans Sport 350!
:rolleyes: I was told it could be a bad set of new points. I filed & cleaned the old points and put them back in and it started up. Wow - I'll put in new ones before I worry about setting the dwell. So between a bad old coil & a bad set of new points I was going nuts! Thanks for the help & bearing with me. Sorry about the duplicate posts, I didn't think they were going through.
