sub system
  • Thread starter Thread starter melvz
M
melvz
:eek: whats the best way to wire the system in a 97 G.A. se...... in my previous vehicle i ran the power cord from the battery up by the hood to the door in to the car and then hid it with the trim by the door and to the backseat where i found a hole and bingo in the trunk i was.... sounds kinda hickish... i know:o .... i want my new wire job to be something that i dont have to see everyday.... any advice would be great!
97 grand am se owner
melvz
you need to put the wire through the firewall then under that carpet. It's kinda easy to get to. the hole should be under the carpet by the pedals
you definantly need to go in through the firewall. Then you can run the wire down by the kick panel, and along the carpet to the rear.....
well i had zero gauge wire and felt lazy so i just ran it under the car and drilled a whole under the rear seats and into the trunk.
