Suggestions on popping out dent
WillV
San Francisco, CA
I have a dent at the left rear quater panel and I thought by removing the interior panel I could get access to the panel from the inside and pound it out. I begun removing the interior panel and now I'm stuck not considering that the load leveler unit will block the way. It seem like a lot of work to remove the load leveler to get access to the outside panel. Should I just have the dent pulled instead of pounded out? Suggestions please guys. Thank you!
There are companies that specialize in what you are trying to do using suction cup devices. They typically have a name such as Paintless Dent Repair. Google to find some in your area.
