Hello my daughter recently purchased a 2000 sunfire(2.2L). The heat was blowing cold air. When i removed the thermostat house so i could check it there wasn't one present. I installed a 180 degree thermostat. The car now has heat until it hits around 195 on the gauge then it looses heat. Temp gauge will climb to just under 260. The radiator is cold however(i can place my hand on it). It appeared to have a new water pump on it but i replaced it anyway. I've borrowed a block tester kit from a buddy. Has anyone ran into this issue,if so what was the fix? My gut tells me that if it's in the head the radiator would still be getting warm.
