Sunfire turns but does not start
cooper57
My 2000 Sunfire turns with power but won't start. Any help would be appreciated.
ok bud first is it a 2.2l or 2.4l engine this makes a lot of difference in advice if it is a two point two liter and the engine is turning but isnt sparking replace you spark plug wireset distributer cap and rotor button. The main cause of the turning but not starting is most likely a lack of spark. now if it is a 2.4l its either your ignition coil coil packs and spark plugs again a lack of spark if you need anymore help you can contact me at Wyattwm90@aol.com
a full tune up was done within the last year.
new plugs ,wires, distributer cap,rotor etc.
the engine turns however the engine will not start
its not the battery ,the engine turns strongly until drained
thanks for your reply
response strongly appreciated
get your starter seliniod checks
Again I appreciate your response
This vehicle is my daughters vehicle
Help was requested on her behalf
Where can I locate the starter selinoid
well if the engine turns it's not the starter solenoid. Did you check if there is spark going to the plugs, did you check the fuel pressure in the rail?
thanks for your response
I will look into your suggestions and respond the following day
thx again
