swapping guage cluster
  • Thread starter Thread starter rusty Shackford
R
rusty Shackford
I have a 91 grand am with a 2.5 4 cyl and the guage cluster doesn't have a built in tach but I have an opportunity to get a cluster with a tach from a 89 with a 2.3 and another from an 88. Does anyone know if this would be a direct replacement or would there be some rewiring to it. I want to keep the car stock as much as possible but would like to have the tach also.
If you want a tach buy an aftermarket one you won't be able to swap, the cluster the wireing is specific to the year and model / engine combo which prevents swapping in most cases and there is no way to rewire a factory cluster to work with a non tach equipped cluster the wireing is all different and is usually changed on the printed circuit on the cluster anyway..
Thanks for the info. That's what I like about pontiacs and fords. You can just about park 2 cars of the same year and model side by side and more than likely the parts won't swap from one to the other.
:rolleyes:
:rolleyes:
Dont feel bad it's that way with most cars these days and it will only get worse as time and emission standards get tougher ...:(
