ericv1984
My car has had a long crank for a while now, and now the theft system light comes on but not all the time. I thought the long crank was from the starter and one day would not start all together. So, I ordered a used one off eBay and got it installed and the car starts but has a long crank again so I was thinking maybe it's the starter again since it was used. But the theft system light is making me think it's the ignition lock tumbler or ignition/starter switch.
Could a failing ignition lock tumbler or ignition/starter switch cause the theft system light to come on intermittently?
And I'll give you a scenario so you know what I mean by intermittently...
Tonight, I started the car to go to the store which is 4 miles away. Upon cranking it, I noticed the theft system light on and didn't go out. It stayed on all the way to the store. Parked, went inside and came back out a few minutes later. Cranked the car and it started but the light wasn't on anymore.
That has happened a few different times, and when the theft system light is on it often takes longer for the car to crank.
