bubbagumpshrimp
- Dec 5, 2013
PO128 + Running Warm---> Hot = Bad Thermostat? I figure that's a bit of a Captain Obvious question, as the PO128 code specifies "Coolant Thermostat (Coolant Temperature Below Thermostat Regulating Temperature), but I figured that I'd ask. That and this is definitely the cheapest fix as far as running hot goes (well...that and checking the coolant level), so I'll start here.
I see that it's just two bolts to remove to get to the thermostat. Is there any catch here (i.e. bolts prone to breaking)? Thank you.
