carguy2992
- Jul 20, 2010
I have a 1986 Fiero 2m4 and I need to replace the thermostat. Where is it located and do you have any advice about my problem. Thanks
go get yourself the chiltons or haynes manual it will show you this. Fiero's are notorious for having overheating problems especially if you're in the south. the factory fan switch is set at 235 which is to late for some cars to turn the fan on but with a stuck thermostat that wouldn't matter anyway. so check that it even works. make sure your cooling system is full as well.
then why did my brand new one off the showroom floor start on fire after only having it for 800 miles??
