People,
i replaced my front struts 12 years ago and forgot how to remove (then tighten) the top 18mm nut on the strut cap. That cap has a depression in the center cap preventing one to put a box wrench around the nut while clamping the center stem from turning. I can place a socket around the nut buy then the center stem is blocked by the socket/rachet, preventing anything from gripping/holding down the stem.
How did I do this before??? manual is bad as it shows the guy holding the center stem with a screwdriver while turning that nut. There is no such "cut" for a screwdriver.
Thanks, people.
Thanks, people.
