Torrent 2006 ABS lamp
navi-gps
Hi Again ;)
Guys, where is located ABS Driver (computer?) in torrent 2006?
Best Regards:)
If the light is on you probably have a bad wheel sensor.
Computer Diagnose show Error left front wheel sensor. I buy new sensor and deleted error. But when i did 200 meters again show error left front whell sensor.. I want to check the connection from the sensor to the computer. But i dont know where ist abs driver
Look for a break in the wire harness under the car going to the sensor, the module shouldnt cause only one sensor to throw an error.
You can close the topic. The reason for the problem was just the cable. I replaced the other two wires and cut off the plug, and some solder.
