Where is the cabin air filter located on Torrents? I've checked for a panel inside and around the glovebox, and did some poking around under the hood. Nothing jumps out as where it's located.
Yep - should have looked there first...DOH! What a pita - under the hood, remove the air inlet panel, remove this push pin - that push pin, curse several times because the push pins broke and cost ridiculous $$$, remove the panel, replace and repeat steps in reverse - including several more fits of cursing.
Yep - I got the owners manual. Thanks for your reply.
