Towing Capacity
jerrykid
I have a 2008 Montana and am trying to determine the towing capacity. The owner's manual states that if the vehicle is equipped with a V92 trailering package or heavy-duty cooling package the capacity is 3500lbs. If not, then it is 2000lbs. Can anyone tell me how I can determine if my van is equipped with either of these things?
Thanks.
Hi!
The label is located ( ID ) on the drivers side, behind the rear seats, I believe in the area where the factory jack is stored, just inside the rear hatch.
Your van will tow 2500 lbs. with no towing package components whatsoever .
If you want to tow up to 3500 lbs - ask a dealer.
Pontiac Montana and Chevy Venture collected on a single platform. Therefore, identification labels similar
Perhaps it is useful to you http://www.my-chevy-venture.com/RPO-codes.html#V73
