tucsonsean
Well, I finally changed my motor mounts--they came out in pieces (literally), so I guess they needed it. I got the torque, engine, and rear trans mounts changed (not easy: it takes a contortionist or someone with a better variety of tools than me), and noticed that Partsbin had sent me two front trans mounts. The current mount has 14mm nuts, not 15mm. Otherwise, they seem the same. My question: Can I just drill out the holes in the frame and bracket and use the mount I have, or do I have to take the week and expense required to call, send back the wrong one, and get the right one from Partsbin? A couple of grade 8 nuts and washers from Ace would be faster and cheaper.
