Trouble installing after market stereo into 2001 Pontiac sunfire?
Harold
am installing a Sony xplod gt300 all wires connected cd ejects disc when I press the eject button but no other functuns read some thing about might have to run wire from aux wire on deck to some brown wire on main harness the deck is good as it was running in my other car all connections ar fine as I pluged stock stereo back into the car it seems that with the sunfires you may have to ad an extra wire for some thing switched power and please only answer if you have installed an after market stereo into a pontiac sunfire 2000 or newer thanks and have a great day
It seems with the Pontiac sunfires they are missing one wire on the main wire harness and you have to run a wire. From the red aux wire on the deck wire harness to some brown wire in the main harness so as before only answer if you have worked on the Pontiac sunfire as the cars where made in Mexico and this seems to be an issue with them thank you
off the back of the stereo wireing harness there is a red and yellow + power wire. you might have to hook those right to the positive battery post to get full power. mine did the same as yours only the cd would eject then i hooked those wires to the battery and it works great.
