Hoping someone here can help me troubleshoot my Rally gauges, oil,water and tach do not work, I don't know if the previous owner ever had them working. The IP does have lights blinkers high beam lights working but no gauges. It has a 12 pin plug to the IP is there a trouble shooting that harness and what readings I should get from the pins? The oil pressure gauge goes past 80 when ign. is turned on while the temp gauge does nothing. I have a diagram but it's got to be one of the worst I've ever worked with. Thanks
