Hi,
I am looking to buy either an NOS or good used Working Turbo LOW pressure switch for my 1980 Trans Am. It was assigned GM part #25036179. The Turbo LOW Pressure Switch is located in front of the EGR valve on the intake manifold. It is screwed into a brass junction block that also contains the Turbo HIGH Pressure Switch and PEVR valve. The LOW pressure switch is used to illuminate the medium boost light (when under hard acceleration) on the 'TURBO CHARGE' panel that faces the driver.
Also any referals or leads for someone who might have would be Greatly Appreciated.
Thanks,
John
Thanks,
John
