I
ironhar
I've got a '97 TA. The left turn signal bulb keeps going out. Every time I replace it, it goes out again in a couple of days. The connector was burnt and warped, so I replaced it, but the bulb still blew. The right side connector is burnt as well, but that bulb doesn' t blow. I'm using the correct bulb, 3057, and it's only the left side that goes out. I also replaced the turn signal housing, thought condensation was causing the bulbs to blow, but that wasn't it either. Anyone have any ideas what the next step would be? Any help is much appreciated.
