My wife has a 2000 Grand Am with a 3.4L and just loves the car. It has had an unusual engine stumble since we purchased it with 184k miles on it. The problem occurs in every gear at 2000 rpm if the throttle is held steady or just barely backed off, no problems with acceleration through that rpm range. No codes are set while the problem occurs and the stumble is hard enough to shake the entire car. Mary describes it best as "it feels like the engine fell out and was run over".
To date I have replaced the coil packs, wires, plugs, harmonic dampener, crankshaft sensor (and had it synchronized with the cam sensor) and the intake gasket. None of these repairs have affected the problem and not all of these repairs were in an attempt to cure the problem.
The mass air flow sensor was unplugged and the car driven about 20 miles; this seemed to lessen the problem but oddly did not turn on the SES light or set any codes. So I suspect the MAF sensor may be bad but not setting a code while unplugged is odd.
Any help with finding and correcting the problem will be greatly appreciated. The car now has 220k miles on it and other than this one issue it looks and drives like new. Mary has no plans on letting me replace it, my directive from her is to "fix it"
Thanks for any help you can give us.
