Vacuum hose problem
  • Thread starter Thread starter Unregistered
U
Unregistered
I have a 1994 Pontiac Sunbird that has 19K original miles on it. Yes,
it really was driven only to and from church on Sundays.
I have a vacuum line that looks like it goes into the valve cover and
then connects to two smaller lines through a splitter. Well, it doesn't
connect anymore and I think I'm missing more than a hose.
It sits at the back center of the engine.
I don't have any manuals and wondered if anyone could figure this
out from my sorry description. If I had to guess, I'm missing a
small plastic piece that regulates the vacuum. If I try and
connect the hose directly, it kills the engine.
vacum hose problem
if you are referring to a 4cyl model, i think the hose you are talking about connects the pcv valve back through the intake. this is important, it relieves crankcase pressure.if you are handy to a GM dealer, ask to look on the parts catalogue for a better view.hope this helps.i work at a GM dealer but only check this every other saturday
