vacuum hoses on a 1995
  • Thread starter Thread starter Nicole B
N
Nicole B
Firebird V6 3.4? Does anyone know if there are any hidden vacuum hoses on this car, it has a plenum, and I have checked all the vacuum hoses that I can see from the top and sides, and the one that goes to the MAP sensor.
I suggest you call your dealership and ask to chat to the customer service rep , they should be able to help you out.
The 3.4 engines have some issues with vacuum leaks but it is not usually the hoses, the intake and throttle body gaskets develop leaks on some cars that can be hard to trace
you may also want to check the system for codes if you are having drivability issues
