Have a quadrajet 4 barrel just bought for my 400. Carb had 2 smaller ports and the 1 larger port on the front of carb. Also had a threaded port on rear at bottom. My pcv valve is already hooked up to a port on my intake. Here are my lines that I need to hook up. Power brake booster,distributor advance,heater valve,transmission and 2 lines that are coming from the interior. Can I hook my brake booster to the large port in front and just tee the remaining lines to the other 2 ports on front? Should I cap the fitting in rear or maybe put a fitting on and use for the distributor?
