Valve Cover Removal (from Hell)
Project86FieroSE
Started removal of the Intake manifold on my Fiero to get at the valve covers to adjust the valve lash. Upper Intake off (only took 2 hours) Now I have to remove the fuel rail and mid-level intake to finally get to the area I need to work on. First time really tearing into a motor on a car. Shadetree mechanic, I'm not. :) I can see all the bolts for the covers. Can I get away with leaving the mid-level intake and fuel rail on?:confused: Or is access to the valves going to be a problem?
Never tore into a Fiero, but if you have access to everything, try it, you can always take it apart further if you can't fully access the valves.
Here is the valve train I finally got to. Hydraulic lifters. Can these even be adjusted? :confused:
