Rosita 99
I have this vibrating sound on the passenger side of the dash board which I hear it while driving. It seems like a screw is loose and is rubbing against the plastic (but not sure). Also, if you press your foot against the bottom portion right below the glove box area the sound stops completely.
I just wanted to see if someone else has run into this before and was looking for an escape from opening all the dashboard components.
I guess otherwise I will have to look into all the screws to check if they are tightened enough.
Just thought of sharing.
