Washer fluid not spraying
Ponkin
My washer fluid will not spray. Would anyone be so kind to give advice where to look first?
Wipers function properly, just no spraying when activating.... Don't think the line is frozen either...
Most likely the little spray pump located on the side of the washer fluid reservoir. U can take it off and hook it up to 12v to test it. Good luck keep us posted. Also there is 2 mounted to the reservoir 1 for the front window and 1 for the rear window so choose wisely.
