Water on floor on passenger and driver's side
Torrent419
Bear, DE
I have water coming from somewhere and just the front floor is getting wet. Not the seats. We already ruled out the sun roof so I have no clue where it is coming from. Can someone please help?!?!?!?
If the water is really engine coolant you have a heater core leak
Check the seal where the side window meets the door on the outside. If that is not tight water will come down inside door and end up on floor. Was happening to my wife's '06 for over a year before I figured it out... It was a bit loose so I glued it back in place and have had a dry floor over over 2 years now.
Is it worse when using your A/C? if so your A/C drain could be clogged and running in through your HVAC case.
Had this happen on my son's 08 Torrent. Both passenger and drivers floor were flooded. Ended up being a crack in the plastic tub that carries washer fluid to the rear wiper washer. The tube is tucked under the plastic trim at the edge of the drivers side door that runs along the edge of the floor.
