Just be sure if you are ordering a new pump it has a cast impeller, no a stamped one. The only different 1963 Water pumps are for the Slant 4 engines used in Tempest & Lemans models (the rt bank of a 389 basicly) those ones turn the other way so the impeller is backwards. Found that out the hard way when I owned a 63 Bonneville years ago. They bolt in fine, just won't pump much coolant!
