ajbremer
I'm trying to replace my water pump but I can't get the serpentine tensioner pulley out of the way of the timing belt cover. There seems to be a 1/4 drive spot in the tensioner casting but the gap between the fender and the drive hole is so small I can't get to it. Do I need a special tool? I tried to jack the right side of the car up and removed the wheel but that still doesn't give me access to the tensioner drive spot. Is there some kind of very narrow 1/4 drive (or is it 1/2 drive) tool that is special for this application. It would be awful if I had to jack the motor up and remove an engine mount or two. Help would be very grateful.
