water?
use a water hose and try to find the source of the leak, it could be the windshield or something else in the cowl/firewall area. You can also look under the vehicle to make sure you dont have a hole in the floor pan.
Thanks.
It was supposed to be the type of error, in the roof above the sliding door is some form of plastic strips, maybe there are water leaks?
Water drips well from the overhead console.
Perhaps someone can tell me ?
check your roof rack mainly the two in the front.
