what could be the problem when you find a lot of antifreeze has run out
  • Thread starter Thread starter Bobbie B
B
Bobbie B
of your 1996 sunfire pontiac on the gr? a stream of antifreeze was on the garage floorantifreeze
there are lots of possibilities, you either have to visually look for a bad hose, radiator hole, etc. or have the system pressure tested to find the leak
maybe the car is overheat and the radiator has a hole, or you overfill, could be the sensor. hope this help you
