M
mr. bojangles
...stopping or turning? I rented a code scanner from AutoZone, and first got a random/multiple cylinder misfire code, then I cleared the light. As the CEL kept coming back on, I continued pulling codes and resetting them each time. I got a misfire code for, I believe, each cylinder -- at different times (one time it was cylinder 3, one time it was cylinder 2, etc.). So it appears that any cylinder misfires at any time it so pleases. I tried swapping the entire coil pack/cover/housing (no cracks)/spark plug boot assembly from another vehicle, and the same problems persist. Last year I replaced the AC Delco plugs with Autolites (preventive maintenance), and I have read time and again to only use AC Delco plugs, but I was short on money at the time, and the car has ran fine until now. It would seem awful coincidental for all plugs to go bad at the same time; they appear to have normal wear and I double-checked that they are still gapped properly. The car will only stumble when coming to a stop/slowing down to turn a corner, at which point the flashing CEL comes on. If I just stop, the car dies. If I put it in neutral and continue to give it gas for a short bit, the "loping" idle will smooth itself out to normal, and I can continue driving, but only until I approach another stop or turn. The timing set was recently replaced (preventive maintenance), and the car ran great, so I have ruled out the timing being off. The head gasket is new, as are most seals. There are no leaks of any kind. The fuel pump and fuel filter are also relatively new. I am leaning toward injectors or possibly an O2 sensor, but I honestly don't know for sure; this problem really has me stumped. Thanks again to you guys for reading and for any advice you may give!!
