x_kookoo4kokopuffs_x
- Feb 24, 2010
The Printout says:
1. Cylinder misfire detected on #1
2. Evap. system flow during non-purge condition
3. TP (Throttle Position) sensor
Now here is the thing, about 6 months ago I replaced plugs and wires, had a new Purge Solenoid put on and a new EGR Valve, plus a new timing chain because some plastic thing on the timing chain broke.
The whole issue im having now is that its slowly leaking oil. (the oil light comes on now and then) Doesn't seem to be affecting the oil level though. The shop said that the front seal on the motor is where it's leaking oil. But I heard that the PCV VALVE could cause too much pressure and push oil out the front seal, because it's also pushing oil out of the valve cover.
Im taking it to a shop tomorrow but I would like to know if anyone knows anything about these problems.
By the way its a 1997 Pontiac Sunfire 2.2L
