vivalavazquez22
- May 3, 2010
i just recently bought a pontiac that had lots of engine work done. The car turns over and imidiatly shuts off, the batery is full changed and it has plenty of gas in the tank, and i just checked all of the spark plugs. the only indication of the problem besides it not running, is that the throttle is bone dry and it should be wet from the gasoline so i think somehow the gas is not circulating corectly. anyone know whats rong?
not the throttle plate itself, but if you stick your finger inside of it there should be a tiny bit of moisture from gas
