Wheel speed sensor/electronic issue
pantherfan12
Hello all!
I have a 2007 Pontiac Torrent AWD. I just took it in for inspection and was told by my mechanic that i needed a new LF hub bearing. I replaced the hub assembly and sensor. Now my speedometer and all of my gauges are erratic while driving. I first thought it could be a faulty sensor so i replaced it with another new sensor. I am still getting the Stabilitrak, Traction Control, Service Vehicle Soon, ABS warnings constantly. I have also noticed that sometimes the power steering will give out for a split second and sometimes the transmission seems to buck. (not sure if that is the AWD kicking in or not). I feel that there may be an electrical issue... A side note to mention is that i replaced the driver side door wiring harness a few months ago. When i connected the new wiring harness my driver side door speaker would not work and the small speaker would make a clicking noise when i put the vehicle in drive or reverse. But the power window still worked. I was not having these issues until i replaced the hub bearing assembly and sensor. Not sure if this could be contributing to the electrical issue or not. I also tried removing the ABS fuse and Stabilitrak fuse but that did not work. I appreciate any help anyone can offer! Thank you!!
you need to have the ABS system scanned to determine what the code is
