Where is crankshaft position sensor?
robert78.5
Age
69
Manitoba
My daughters car threw a P0335 code, and has a stumbling idle at red lights.
Where is the sensor located? 1997 sunfire, 4 cyl.
If it's a 2.2 then it will be right next to the coil packs on the back of the engine.
Had it replaced on my old 96 2.2, took off the front passenger tire to get to it. Not sure if it'll be easier from underneath the car with it on jack stands.
If it's a 2.3/2.4 then it will be on the front of the engine above the oil filter. Also a pain to get too. You might need to remove the oil filter or the starter to gain more access to the sensor.
