There is no switch .. the pump is activated by a relay and the ignition switch contacts if it is not running I would check the fuses , and the relay if they check Ok it is probably the pump itself (in The tank) they are not like some ford products that have a cut off switch for the pump in case of a rollover accident that sometimes gets tripped ...
