Where is the outlet for sunroof drain tubes
Carcharoth
I have a 2007 pontiac G5 Coup and I have a water leak into the driver side carpet of the car. By looking at other forums I think the drain tube from the sunroof on the driver side has popped out somewhere just above the pedals before the outlet. Does anyone know where the outlet actually is? I have checked the tubing from the sunroof down to where it goes down just below the windshield but can't see where it goes. It appears that the outlet is encased somewhere in the body panels as on the passenger side water runs out of several little slits below the door, it looks like a sort of gutter system. So I think to find it I will need to take some panels off and would just like to know which ones those would be?
You have confirmed it is a sunroof issue by using a water hose? You are sure it is not caused by a clogged A/C drain? Assuming it is the sunroof, before trying to take things apart, it is doubtful anything popped out, take compressed air and blow the drains out to dislodge any accumulation of dirt.
