Where is the tail light fuse on a Pontiac Montana SV6?
  • Thread starter Thread starter SteveJDM
probably in the fuse block but you should,nt have to remove it to replace a bulb.
Under the hood beside the radiator. Why are you looking for the fuse box to change tail light bulbs? No need to remove or replace the fuse unless it's blown.
No fuse for tail lights
Seaching the fuse in both Underhood and Instrument Fuse Block but can´t find anyone specificially marked for the tail lights. So where is it? :confused:
