My two accessory power outlets (i.e. cig lighter sockets) do not work all of a sudden. I don't see a description of the fuse for the box that's inside the car. Is it possible it would be in the engine compartment box labeled "3 - Auxillary Power"?
Here's the list for the fuse box inside the car:
1 Sunroof
2 Rear Seat Entertainment
3 Rear Wiper
4 Liftgate
5 Airbags
6 Heated Seats
7 Driver’s Side Turn Signal
8 Door Locks
9 Automatic Occupant Sensing
Module
10 Power Mirrors
11 Passenger’s Side Turn Signal
12 Amplifier
13 Steering Wheel Illumination
SPARE Spare
SPARE Spare
SPARE Spare
SPARE Spare
SPARE Spare
14 Infotainment
15 Climate Control System, Remote
Function Actuator
16 Canister Vent
17 Radio
18 Cluster
Fuses Usage
19 Ignition Switch
20 Body Control Module
21 OnStar®
22 Center High-Mounted Stoplamp,
Dimmer
23 Interior Lights
Relays Usage
RAP RLY Retained Accessory Power Relay
REAR DEFOG
RLY Rear Defogger Relay
Circuit
Breakers
Usage
PWR WNDW Power Windows
PWR SEATS Power Seats
EMPTY Empty
Misc. Usage
PLR Fuse Puller
Here's the list for the engine compartment:
Fuses Usage
1 Cooling Fan 2
2 Cooling Fan 1
Fuses Usage
3 Auxiliary Power
4 Not Used
5 Spare
6 Spare
7 Anti-lock Brake System
8 Air Conditioning Clutch
9 Driver’s Side Low-Beam
10 Daytime Running Lamp 2
11 Passenger’s Side High-Beam
12 Passenger’s Side Park Lamp
13 Horn
14 Driver’s Side Park Lamp
15 Starter
16 Electronic Throttle Control, Engine
Control Module
17 Emission Device 1
18 Even Coils, Injectors
19 Odd Coils, Injectors
20 Emission Device 2
21 Spare
22 Powertrain Control Module, Ignition
23 Transmission
24 Mass Airflow Sensor
25 Airbag Display
26 Spare
27 Stoplamp
28 Passenger’s Side Low-Beam
29 Driver’s Side High-Beam
30 Battery Main 3
32 Spare
33 Engine Control Module, Battery
34 Transmission Control Module,
Battery
35 Trailer Park Lamp
36 Front Wiper
37 Driver’s Side Trailer Stoplamp,
Turn Signal
38 Spare
39 Fuel Pump
40 Not Used
41 All-Wheel Drive
42 Regulated Voltage Control
43 Passenger’s Side Trailer
Stoplamp, Turn Signal
44 Spare
45 Front, Rear Washer
48 Rear Defogger
Fuses Usage
49 Anti-lock Brake System Motor
50 Battery Main 2
52 Daytime Running Lamps
53 Fog Lamps
54 Climate Control System Blower
57 Battery Main 1
63 Megafuse
Relays Usage
31 Ignition Main
46 Air Conditioning Compressor Clutch
47 Powertrain
51 Spare
55 Crank
56 Fan 1
58 Passenger’s Side Trailer
59 Driver’s Side Trailer Stoplamp,
Turn Signal
60 Fan 3
61 Fan 2
62 Fuel Pump
1 Sunroof
3 Rear Wiper
4 Liftgate
5 Airbags
6 Heated Seats
8 Door Locks
Module
10 Power Mirrors
12 Amplifier
SPARE Spare
SPARE Spare
SPARE Spare
SPARE Spare
SPARE Spare
14 Infotainment
Function Actuator
16 Canister Vent
17 Radio
18 Cluster
Fuses Usage
19 Ignition Switch
21 OnStar®
Dimmer
23 Interior Lights
Relays Usage
REAR DEFOG
Circuit
Breakers
Usage
EMPTY Empty
Misc. Usage
PLR Fuse Puller
Fuses Usage
1 Cooling Fan 2
2 Cooling Fan 1
Fuses Usage
3 Auxiliary Power
4 Not Used
5 Spare
6 Spare
13 Horn
15 Starter
Control Module
21 Spare
23 Transmission
25 Airbag Display
26 Spare
27 Stoplamp
30 Battery Main 3
32 Spare
Battery
36 Front Wiper
Turn Signal
38 Spare
39 Fuel Pump
40 Not Used
41 All-Wheel Drive
44 Spare
48 Rear Defogger
Fuses Usage
50 Battery Main 2
53 Fog Lamps
57 Battery Main 1
63 Megafuse
Relays Usage
31 Ignition Main
47 Powertrain
51 Spare
55 Crank
56 Fan 1
Turn Signal
60 Fan 3
61 Fan 2
62 Fuel Pump
