whistling under the engine when the engine is warm
vacuum leak? drive belt? alternator bearing? You will have to isolate where the noise is coming from.
No vacuum leak and no alternator bearing and no drive belt what could it be is under the engine ?
Not much under the engine that can whistle. Have you crawled under to look?
transmission? we could guess all day long, you have to isolate the issue or take it to a shop
