Why does my 97 Pontiac Grand Am keep randomly cutting off?
  • Thread starter Thread starter TokenJoker00
T
TokenJoker00
I have a '97 Grand Am that has the 4 cylinder 2.4L engine. At VERY random times, my car will start sputtering and shut off. The only way I can get it to crank is if I wait approx. 20-30 minutes and crank it again. If I try to crank it right after it cuts off, it will start then sputter or just not start at all.
I have already changed the TPS sensor and and the ignition module.
Other info:
-I can drive the car for over 500 to 600 miles without any problems. But also, sometimes it dies off twice in the same day.
-The check engine light comes on, but throws different codes each time.
It threw TPS sensor code so we changed it.
It threw a Cylinder 1 misfire, but when i cranked it 30 minutes later, it wasn't missing.
-The check engine code also said it was the Crank sensor(about 2 weeks ago).
Could it be the crank sensor? What other things can I check?
it can be the spark plugs or the crankshaft sensor. i got the exact same car and when my car did that it was the fuel pump going bad and it cause 253 dollars for a new one
Yes Crank sensor could really really do that , it controls the ignition module and injectors , ecm too. It was common with that also, cheap and easy to change. If you dont have a good scan tool to watch crank sensor data then gamble and change it.
When is the last time you had all your spark plugs and wires checked. I had that happen and it was a faulty wire.
