I have a 1986 Fiero SE that has a bad engine and a 4 speed manual. I have purchased a 2.8 V6 5 speed engine and transmission. I have begun taking the 2.8 out of the 86 and have noticed some subtle differences in the routing of the heater hoses, the water pump is different, and the transmission shift cables and mounts are different. How much work will it be to swap these engines and will it work? Also, the 88 V6 has had the wiring harness cut to shreds, I guess it was a quick removal since the old owner was doing a V8 conversion. Will my 86 Wiring harness work on the 88 2.8?
Thank you,
Brian
Thank you,
Brian
