will a pontiac 400 fit inside of an 82 firebird?
  • Thread starter Thread starter Brad
B
Brad
will a 1975 pontiac 400 fit inside of 1982 firebird without cutting and fabrication
It will fit but not without some major work ..the pontiac engines were never designed to work with the chassis .. so it would require a bunch of modifications to the exhaust, starter, wireing, and possibly the frame and firewall areas ..
it is by no means a direct swap, you would also need to change the transmission and the pontiac transmissions have no provision for a torque arm ..so there's more fabrication ..
