Will this fit?
Blackdog
I have a 2002 Pontiac Sunfire with a 2.2 litre engine. The engine crapped out on me and I need to change it. I have a line on one engine that is VIN code F. The one in the car is a VIN code 4. Will the vin code F engine fit up into the vehicle with the VIN code 4? Thank you.
If you have the overhead valve 2.2 , VIN 4, and the other engine is the double ohc 2.2, VIN F, you need the wiring harness and ECM.
